Hybrid water heaters....
heatpro02920
Member Posts: 991
Which brand do you use, I haven't done many, since I have been waiting to see where the technology goes...
I have only used the ao smith models {havent used the Next yet} Voltex mainly
I am wondering if anyone has good luck with other units, I have a proposal due for 6 units in a multi family home, and would like to offer my customer the best available for their money...
No thoughts on these units?
Anyone have any experience with them, I seem to be getting a ton of calls on them since people are nitcing the $1100 of rebates they come with...0 -
i am familiar with rheem
i installed 2 in the past couple yrs, they r the most popular ones that my suppliers sell if that says anything.0 -
Good for warm climates...
The heat pump just takes heat from the room and puts it in the tank. If you are in a climate where you heat the space, you are not saving anything. In fact you are wasting energy in the transfer.
In a warmer climate where you would be running AC to cool the air it makes a lot of sense.
Albert Einstein0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 15.6K Strictly Steam
