Need Solar Science Project Idea for eigth grader........
Mad Dog_2
Member Posts: 8,356
Hey you"ll. My boy Matt Jr. and I want to build some demonstration model for experimentation to showcase solar energy. My gut is to do something with Solar Thermal but I think PV might be simpler. We don't have a lot of time either. Any suggestions? Perhaps their are kits that we could buy on the web? Thanking you in advance. Mad Dog
Can you make...
a very simple solar collector out of pex tubing and paint it black? It wouldn't have to last a long time so the pex exposure would not be as issue. Use a 007 and a small water heater tank... a couple gauges he and there.Viola!0 -
paint will not stick to PEX
black PE pipe is really inexpensive and works quite well. There are plenty of homebrew solar thermal collector plans out there. Maybe re-post this in the Solar section?0 -
solar pv
projects and kits are easier to find. I took a small PV model car to Maxs class many years ago. Real Goods had dozen of projects in their catalog.
or this simple one.
www.treehugger.com/clean-technology/diy-solar-powered-cockroach-toy-is-a-perfect-kids-project.html
A simple solar HW would be a coil of 1/4" copper painted black and a small circ, or a thermosiphon set up.
hrBob "hot rod" Rohr
teach solar and recycling
from radio shackBob "hot rod" Rohr
- 87.2K THE MAIN WALL
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 75 Pipe Deterioration
- 6.4K Radiant Heating
- 15.6K Strictly Steam
