bryant gas furnace, no heat..
roxy
Member Posts: 1
Furnace quit on us and cant get repairman out till tomorrow... Its a bryant gas furnace 350aav. I cant figure out the led code as to what the problem may be, when I try to reset it it just blows cold air for about a minute then turns off. Please help!!
led code
That furnace should have a two diget code. The first number determined by the short flashes and the second number by the long flashes. So one long flash followed by 3 short flashes = error code 130 -
350aav
Didn't see and Bryant 350aav. There is a 350mav which is a 90%er. Sounds like you need and inducer motor or a circuit board.0 -
On partners
And still will only show me 350mva's0 -
can't
use my link?0 -
I did
Just don't know why I can't get it my own self. Went to lit. then prod data put in 350 and only mva's come up.0 -
front, back, or side door
i searched 350aav and came up with.. http://www.catalog.bryant.com/wcs/proddesc_display/0,,CLI1_DIV42_ETI4641_PRD805_SIT70,00.html0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
