Williamson aka Weil Mclain Base Cracked Base
ALIGA
ALIGA Member Posts: 194
Have you ever seen this type of crack on the boiler base?  One month old boiler.
Any ideas?
Should I be concerned? Thank you in advance.
Pic orientation: looking at boiler from the front, right side bottom.
  • kcopp
    kcopp Member Posts: 4,682
    looks like....
    it may have been dropped. Not a huge deal as it is well supported on the blocks. It will NOT cause a leak or anything. Is it a gas boiler?
  • ALIGA
    Gas boiler
    I have been religiously checking on it every week or so to ensure there are no leaks, and this is the first time seeing it.  I am wondering if there was a defect in the casting.  There are no leaks at the moment.
