Williamson aka Weil Mclain Base Cracked Base
ALIGA
Member Posts: 194
Have you ever seen this type of crack on the boiler base? One month old boiler.
Any ideas?
Should I be concerned? Thank you in advance.
Pic orientation: looking at boiler from the front, right side bottom.
Any ideas?
looks like....
it may have been dropped. Not a huge deal as it is well supported on the blocks. It will NOT cause a leak or anything. Is it a gas boiler?0 -
Gas boiler
I have been religiously checking on it every week or so to ensure there are no leaks, and this is the first time seeing it. I am wondering if there was a defect in the casting. There are no leaks at the moment.0
- 120 Geothermal
- 394 Solar
