protection tubes?
ChrisJ
Member Posts: 17,073
I keep seeing things regarding protection tubes being needed for water probes on commercial boilers.
This seems like a good idea, why don't residential boilers have this as well?
For example : <a href="http://youtu.be/HG0M9wPDnzY">http://youtu.be/HG0M9wPDnzY</a>
Pressure?
I'd guess that some commercial boilers are operating at high pressure so the danger of a bursting glass is a more serious concern.
3PSI gauge0 -
Nope
The protection tube is to keep the LWCO probe in a calm environment like the gauge glass so it gets a more accurate reading.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Money
Well then it has to be the money, nobody wants to put anything on a boiler that doesn't increase sales to cover the cost - no matter how small.
3PSI gauge0 -
Sad
Bob, isn't that sad that you could assume that and probably be 100% right?
Probably the same reason there is no anode rod.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
- 167 Indoor-Air Quality
