protection tubes?
ChrisJ
ChrisJ Member Posts: 17,070
I keep seeing things regarding protection tubes being needed for water probes on commercial boilers.
This seems like a good idea, why don't residential boilers have this as well?
For example : <a href="http://youtu.be/HG0M9wPDnzY">http://youtu.be/HG0M9wPDnzY</a>
  • BobC
    BobC Member Posts: 5,539
    Pressure?
    I'd guess that some commercial boilers are operating at high pressure so the danger of a bursting glass is a more serious concern.
    Bob
    3PSI gauge
  • ChrisJ
    Nope
    The protection tube is to keep the LWCO probe in a calm environment like the gauge glass so it gets a more accurate reading.
  • BobC
    Money
    Well then it has to be the money, nobody wants to put anything on a boiler that doesn't increase sales to cover the cost - no matter how small.
    Bob
    3PSI gauge
  • ChrisJ
    Sad
    Bob, isn't that sad that you could assume that and probably be 100% right?
    Probably the same reason there is no anode rod.
