Bathroom renovation - how to remove and reconnect baseboard heater
hoopsmt44
Member Posts: 2
Hello,
I am in the middle of a full bathroom renovation. In order to replace the subfloor all the way to the wall and the sheetrock behind it, I need to remove a functioning cast iron baseboard heater for a short time and then reconnect it and return it to functional. There is a shut of value in the basement near the boiler for this radiator alone, so it will be easy to isolate.
I do not know how to remove the water from the heater to prevent spilling it all over the ceiling below. Also if I can mechanically disconnect easily or have to use a torch to disconnect the copper fittings that lead to it? Finally once I get it back into place, how do I re-fill with water and purge the air from that circuit?
Thank you for any help!
Your project?
In short the electrical power and gas need to be shut off and tagged out. You can then shut off the water supplying the boiler and drain through drain cock. I rather you call a contractor to do this as it will give you less head aches in the long run. It will not take long at all to do this so give him a call.
Mike T.0 -
Thanks
Thanks for the response. If that's the case, I won't take a chance on it.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 962 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
