Baxi boiler issue
brnrman1
Member Posts: 32
We have been trying to solve a problem with a Baxi Luna 3 Comfort 3.10FI. When the proving switch closes the board has a short and we have 30 volts DC power on the leads to the proving switch. We already ran a new electrical supply from the panel to the unit all the switches ohm out good but still having the problem with the limit string
"Mitch"
Roger Mitchell
Senior Technical Representative
Energy Kinetics
Roger Mitchell
Energy Kinetics
Baxi
Have you called Marathon? They are the North American rep.- (800)461-4657.
From what I've heard and it may be just a rumor, a Korean group has purchased the company. Most if not all of the familiar techies are gone; Jamie, Roy, Aaron, Mike.....8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
baxi help
Yes the tech rep from J and K sales is coming for a second time tomorrow just rying to reach out for more input"Mitch"
Roger Mitchell
Energy Kinetics0 -
Let us know
when you find a solution.
Thanks.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
the board is shorting?
how do u know the board is shorting, what is it doing? smoking? poping a fuse?0 -
How did you make out
How many zones are you running of the boiler? Are you talking about 1,2 on M1 side of board?
I have installed Baxi boilers for 10years plus. I started installing the old style 310 and now most of the HT 380. The biggest thing you need to tell your customers you need to tune up every year. Just like oil systems just easier. flush out DW heat exchanger if the town has bad water.
What town are you in?0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 989 Plumbing
- 389 Solar
