drop header piping?
jonny88
Member Posts: 1,139
Hi,i have been looking at pics of drop headers.my ? is why do you need unions on the risers.Thanks
Unions
I can't speak for everyone but I used two 12" nipples for each riser and needed something to couple them, so why not unions? This also allows me to replace the boiler with an identical one really easy.
I don't think you "need" them there but you're going to need one somewhere just to get the parts together.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
you dont,
if you have one in the header.gwgillplumbingandheating.com
drop header piping?
thanks for your answers.from the pics the unions do me it look very sharp.i was asking as i have a steam boiler coming up and am going to try my first drop header.thanks again0 -
A drop header
is only one part of a good installation- the pipe sizes and general configuration have to be right also. But I'm sure you know that. Post some pictures when you're done.All Steamed Up, Inc.
Consulting0 -
header oversized?
can u oversize a drop header to where it causes inefficientcy?0 -
Theoretically... maybe,
but I'm not even sure what the theoretical limits are, and practical limitations like budget and available materials impinge on the size a lot sooner. It really has more to do with diminishing returns than theoretical limits. At a certain point it just doesn't make sense to pay for bigger pipe and fittings because the expense can't be offset by any comparable increase in efficiency.Just another DIYer | King of Prussia, PA
1983(?) Peerless G-561-W-S | 3" drop header, CG400-1090, VXT-240
