drop header piping?
jonny88
jonny88 Member Posts: 1,139
Hi,i have been looking at pics of drop headers.my ? is why do you need unions on the risers.Thanks
  • ChrisJ
    ChrisJ Member Posts: 17,070
    Unions
    I can't speak for everyone but I used two 12" nipples for each riser and needed something to couple them, so why not unions?  This also allows me to replace the boiler with an identical one really easy.
    I don't think you "need" them there but you're going to need one somewhere just to get the parts together.
  • gerry gill
    gerry gill Member Posts: 3,083
    you dont,
    if you have one in the header.
    gwgillplumbingandheating.com
  • jonny88
    drop header piping?
    thanks for your answers.from the pics the unions do me it look very sharp.i was asking as i have a steam boiler coming up and am going to try my first drop header.thanks again
    Steamhead Member Posts: 18,205
    A drop header
    is only one part of a good installation- the pipe sizes and general configuration have to be right also. But I'm sure you know that. Post some pictures when you're done.
    Consulting
  • pipeking
    pipeking Member Posts: 252
    header oversized?
    can u oversize a drop header to where it causes inefficientcy?
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,919
    Theoretically... maybe,
    but I'm not even sure what the theoretical limits are, and practical limitations like budget and available materials impinge on the size a lot sooner. It really has more to do with diminishing returns than theoretical limits. At a certain point it just doesn't make sense to pay for bigger pipe and fittings because the expense can't be offset by any comparable increase in efficiency.
