ccf to therm
steamychick
Member Posts: 55
I am doing some detective work on my gas consumption as relating to my steam heat system, and am curious (as usual) about the switch that the gas co. made to go from billing by ccf's to therms. I know ccf is measuring volume, while therm is measuring energy due to variances in content (impurities,etc.). So now on my gas bills I have different therms billed at different rates - which I understand, but my question is, why are they needing to differentiate that now when they never did when billing by ccf's? just wondering
Conversion Factor of some sort
Just looked my bill to see about ccf.
Residential Sales Service
Explanation of natural gas used
Current reading: 929
Previous reading: 837
Difference (ccf) 92
Conversion factor X 1.19060=109.5
Natural gas used (therms) 109.5
I do not know the reason for this CONVERSION FACTOR of 1.19060 either.
I do know that it changes each month.
I'm sure one of the Pro's or really smart homeowners can answer this question.Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Old Burnham V8 Removal0 -
gas co. allergies
The cynical / utility co. allergic side of my brain is starting to wonder wether they changed because it is more beneficial to their bottom line. But I'm sure there's a very long and very complicated rocket-science-y explanation just full of run-on sentences about why. Just haven't heard it yet. I thought-for a split second- about calling the gas co. to ask. Then I came to my senses. Don't want to spend half the day trying to get a live human on the line. Would rather spend half the day on this wall. Much more pleasant!0 -
They're just trying to charge for what you're actually using.
You use gas to produce heat, and the amount of heat natural gas combustion yields depends on the composition of the gas, which varies constantly. Unlike LP gas, natural gas contains a mixture of aliphatic hydrocarbons--primarily methane, but also lesser amounts of ethane, propane, butanes and pentanes--and a motley assortment of noncombustible gases like nitrogen, carbon dioxide, hydrogen sulfide, water vapor and helium. The proportions of these gases determines the energy yield.
But your gas meter doesn't measure therms; it measures cubic feet. On average, 1 ft³ of natural gas yields about 1,000 BTU. One therm is equal to 100,000 BTU; therefore, 100 ft³, or one ccf, yields approximately one therm of heat energy.
In order to charge you for the heat energy you actually use, the gas company analyzes the composition of the gas they deliver to determine its heat content, so, by the time they get your meter reading at the end of the month, they know exactly what was in that gas you used. This analysis allows them to calculate--pretty easily, actually because of the way the units shake out--how much more or less than a therm you got from every hundred cubic feet of gas they delivered.
When you think about it, this really favors consumers. If you just paid for the volume of gas you used they could sell you gas that was mostly air. That would kinda suck. Or they could try to standardize the chemical composition, like propane, to keep the heat content per volume constant, but then it would probably cost as much as propane. That would kinda suck too.Just another DIYer | King of Prussia, PA
Excellent explanation Hap_Hazzard! My curiosity is in the fact that, assuming the therm is not a newly discovered thing, they've only recently switched from the ccf to the therm.Just wondering why now? Oh, and please excuse my attitude about utility companies. I have a very old house and utilites love me much more than I love them. Trying to work on that.0 -
Great Explaination Hap
This answer is why this is such a great "informational web site". Its well thought out, well conveyed, answers. Thanks Hap.Weil McLean SGO4, Riello Gas Burner
404 sq ft EDR
Why now?
It could be due to pressure from consumer watchdogs, insisting on charging based on value rather than volume.Just another DIYer | King of Prussia, PA
Thanks!
I try to contribute where I can, but there's no way I'll ever give back a tiny fraction of what I've learned from all the smart, experienced, wise and generous people on this site--especially because I'm still learning.Just another DIYer | King of Prussia, PA
Past Due
Many utilities made this switch a long time ago. In our area, I think it was around 15 years ago.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
Why does this post make me think of this...
Vinny Gambini:
I object to this witness being called at this time. We've been given no
prior notice he'd testify. No discovery of any tests he's conducted or
reports he's prepared. And as the court is aware, the defense is
entitled to advance notice of any witness who will testify, particularly
to those who will give scientific evidence, so that we can properly
prepare for cross-examination, as well as to give the defense an
opportunity to have the witness's reports reviewed by a defense expert,
who might then be in a position to contradict the veracity of his
conclusions.
Judge Chamberlain Haller:
Mr. Gambini?
Vinny Gambini:
Yes, sir?
That is a lucid, intelligent, well thought-out objection.
Vinny Gambini:
Thank you, Your Honor.
Judge Chamberlain Haller: Overruled."Hey, it looks good on you though..."0 -
:-)0
- 109 Chimneys & Flues
- 977 Plumbing
- 387 Solar
- 17 Recall Announcements
