Boiler cleaner
Jrock
Jrock Member Posts: 11
My new boiler is showing a lot of rust in g.g. Water level surging , some one told me to skim boiler iam not sure if that's the best thing to do need some help suggestions , and is there any Safe chemical to add or flush with .? Thanks
  • nicholas bonham-carter
    nicholas bonham-carter Member Posts: 8,578
    Proper boiler cleaning
    The manufacturer will have a proper way of cleaning a new boiler, also called skimming (do a search). Peerless boilers specify putting washing soda into the boiler, and simmering for a little while, then draining, and followed by skimming for several hours, several times.
    The installer, if he followed instructions will have left .a skimming port and valve specifically for that purpose.--NBC
  • Jrock
    Thanks
    Good advice I found out exactly how boiler manufacturer recommends skimming
