Combustion Analyzer
Tom_133
Member Posts: 933
Hey Guys,
I currently have a Wohler e335 and it works ok. I like it because the calibration time through my wholesaler is 3 days, which means less down time. I don't like how slow it is when reacting to tuning changes. This may just be the way they all are, but I typically wait 60-90 seconds and then finally it starts to change. My question is I need a back up unit, and was curious if anyone else is using a wohler, UEI, Bacharach, etc that they like. Oh, and how important the upgrade to a NOx kit would be?
Tom
Montpelier Vt
Montpelier Vt
Tech 60
I like my Bach Tech 60. It's about 10 years old and has always seemed to very well for me. The O2 sensor gets changed out about every 5 years per the manufacturer's suggestion.
My boss carries a UEI on his truck... and it's only 2 years old has had to be sent for repair 3 times, fortunately the first two times was under warranty, but still.
We get them both calibrated every 6 months to a year.0 -
Bought a UEI Eagle X about a year ago
5 years of calibration and refurb (including sensors) included. Nice machine, quite different than their earlier stuff. NOx option can be added at any time with a trip to the factory. Opted for the BlueTooth option instead of a printer - app generates an email on my phone, which is better than paper in my world.0 -
60 Seconds?
My econometer reacts instantly almost instantly. Thats very strange.. So, if you have the probe in the stack and open / close the air gate you need to wait 60 seconds to see the numbers change? Thats very strange indeed. Mine numbers change instantly. Sure, the stack temp is always on the rise unless you let it run 15 minutes so the numbers never become 100% stable but it reacts instantly.0 -
CO
My CO sensor is quite quick, but the Co2 and the o2 is super slow. Of course those are the ones you want to be quicker. It stinks on a small single zone system when you need to lock it in high fire and just as the numbers start coming back it shuts off! because its at high limit! That is enough to make me spend almost any amount on a good fast analyzer.Tom
Montpelier Vt0
- 87K THE MAIN WALL
- 58 Biomass
- 113 Chimneys & Flues
- 109 Geothermal
- 161 Indoor-Air Quality
- 994 Plumbing
- 391 Solar
- 55 Water Quality
