domestic hot water too hot
Homeowner here with a Buderus Logimax GB 142-45 unit with a Buderus S-120 hot water tank connected. System has "outside" control so regulates itself depending on outside temperature.
Heating set on auto, hot water set on 120. However when weather gets cold domestic hot water temperature over rides setting and becomes very hot.
What to do/ check?
  • Zman
    Zman Member Posts: 7,609
    Steam
    That shouldn't happen. That boiler should be piped for domestic priority.
    You should probably repost this in a section other than strictly steam. Pictures of the piping at the boiler would be helpful.
    Carl
    Albert Einstein
  • tallents
    tallents Member Posts: 10
    Thanks, new to system and didn't realize it was area specific
