domestic hot water too hot
tallents
Member Posts: 10
Homeowner here with a Buderus Logimax GB 142-45 unit with a Buderus S-120 hot water tank connected. System has "outside" control so regulates itself depending on outside temperature.
Heating set on auto, hot water set on 120. However when weather gets cold domestic hot water temperature over rides setting and becomes very hot.
What to do/ check?
What to do/ check?
Steam
That shouldn't happen. That boiler should be piped for domestic priority.
You should probably repost this in a section other than strictly steam. Pictures of the piping at the boiler would be helpful.
Albert Einstein0 -
Thanks, new to system and didn't realize it was area specific0
- 50 Industry Classes
