my first drop header install EGH-85
Motty
Member Posts: 8
hi all,
Pics of EGH 85 install. Any feedback is appreciated.
Thx
Motty
Thx
Motty
That's one way to do it.
Looks pretty ok considering you kept the old header. You should add a valve to your Hartford Loop, though. And you need a skim valve.
Well done overall.Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Valves
John,
I have a nipple and cap on the right side for skimming ( already skimmed the boiler). Why do recommend a valve on the Hartford loop? What is the advantage?
Thx0 -
Not speaking for John here
but a valve on the Hartford loop lets you drain and flush the boiler or the return without having to drain the other to the level of the Hartford. It will also allow you to flush more gunk out of the mud leg when you open that drain on the bottom of the equalizer by preventing the condensate from the return from flowing down and washing it back into the boiler.
And, by the way, nice job. I think the tricky ones like this show the most skill and creativity.Just another DIYer | King of Prussia, PA
I've built headers like that
when there was no other way to get both steam supplies on the same end of the header.
Nice work.All Steamed Up, Inc.
Consulting0 -
well done!
I like it. I think you did a nice job. Welcome to the drop header club!gwgillplumbingandheating.com
thanks
thank you for the kind words and advice.
motty0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
