Uponor Control Wiring
Roscoe
Member Posts: 23
I have a radiant heat system with the following controls:
- Uponor control module (A3030004)
- Uponor 8-zone manifold (106604)
- Uponor actuator (501)
I am planning to connect three additional loops for a large kitchen/breakfast area, with a single thermostat. I have two slots available on the control module. Since the actuators are all planned to go on and off at the same time, can I jump the thermostat inputs to a single slot on the control module - and the outputs from the same single slot on the output side to all three actuators?
Let me try to clarify...
I think there's 3 options:
1. Single thermostat jumped to 3 different inputs on the control module. On the output side, use three separate outputs, each controlling it's own actuator
2. Single thermostat connect to a single input on the control module. On the output side of the control module, use a single output and jump it to three actuators.
3. Three thermostats, three inputs to the control module, three outputs to actuators. This is the most straight-forward way, but will require an additional control module and 2 additional thermostats. $300 additional, and the thermostats will all be in the same room set at the same temperature.
My guess is option 1 would be preferred, but I'd appreciate input from the experts.0
