Question on Tape for Pipe Insulation
TeachMeSteam
Member Posts: 128
Hey guys.
What tape do you use to hold pipe insulation together? It seems the one I've been using from Home Depot seems to fall apart a few months later due to the heat. Or maybe I should be wrapping more of it?
Are there any youtube videos or websites that teach how to put pipe insulation on pipes? I know it's easy but had some trouble with the joints.
Thanks for the help.
Pipe Insulation
The original asbestocel was held on with metal straps. I did the same thing with cable ties. If I ever have to remove insulation just cut the ties. They make special pieces to go over tees and elbows.0 -
What do you use to seal the pipe insulation together? The space between each pipe segment?0 -
Pipe Insulation
Nothing just butt the insulation together. The old insulation wasn't taped at the joints.0 -
tape
I use PVC tape I got from the same website I bought the insulation from. Home depot didn't have anything I wanted. I was after 1" quality insuation and the stuff I bought from http://www.buyinsulationproducts.com/ also has a plastic vapor barrier, not paper.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
ASJ
I think you want to look for something called All-Service Jacketing (ASJ) tape.0 -
i like to use
an application of childers mastic followed by a wrap of thin skrim like cheese cloth.gwgillplumbingandheating.com
Eww
I could never use the phrase "I like to" when talking about insulation of any type.
If I didn't hate it so much the rest of mine would be done instead of sitting in a box in the basement.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
white PP tape
3M makes it - very common in 3" width which is it's used for "bubble wrap" inside metal buildings. I had to order a case to get the 1-1/2" we use.0 -
Near Boiler Pipe Insulation
Chris,
I'm looking at your pictures. I like your near boiler piping.
What did you use to insulate your near boiler piping?0 -
Insulation
Thanks for the compliment, I later insulated one of the king valves and then decided insulating sucks and kind of gave up.
I just finished doing a small section of main that popped and squeaked when you walked on the floor over it. Now its nice and quiet. I still need to do some other sections of runouts but its kind of a low priority unfortunately.
I used insulation and PVC covers that come with a small blanket of insulation along with PVC tape. It all came from http://www.buyinsulationproducts.com/
The stuff is by no means cheap though unfortunatly. I also used a round cutting tool along with wooden dowels that came from them where I put supports. The wood keeps the pipes from making expansion noises as well as keeping the support from crushing the insulation.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
