150psi press relief
Techman
Techman Member Posts: 2,143
.It has 3/4 pipe fittings .What type of systems would this press relief  be used on?
  • Mark Eatherton
    Mark Eatherton Member Posts: 5,876
    Heat exchanger...
    Shell and tube or plate and frame heat exchangers can handle that kind of pressure. And I am positive that certain (industrial power) boilers can handle that pressure too, but their threads won't be 3/4"...
    There are also T&P relief valves with 150 pound capacities.
    I hope you didn't find it on a 30 pound appliance.
    ME
    hot_rod Member Posts: 28,263
    air compressors
    use 150 or 175 psi relief valves
  • Bob Harper
    Bob Harper Member Posts: 1,187
    tag markings?
    If the rating tag also indicates it being rated for 210F at 150 psi then it is a temperature/ pressure relief valve such as required on water heaters.
