150psi press relief
.It has 3/4 pipe fittings .What type of systems would this press relief  be used on?
  • Heat exchanger...
    Shell and tube or plate and frame heat exchangers can handle that kind of pressure. And I am positive that certain (industrial power) boilers can handle that pressure too, but their threads won't be 3/4"...
    There are also T&P relief valves with 150 pound capacities.
    I hope you didn't find it on a 30 pound appliance.
    ME
  • air compressors
    use 150 or 175 psi relief valves
  • tag markings?
    If the rating tag also indicates it being rated for 210F at 150 psi then it is a temperature/ pressure relief valve such as required on water heaters.
