Where do you go?
Clarry
Member Posts: 1
Selected local company to install Burnham boiler, complete oil to gas conversion. Water hammer is excessively loud, water guggling, banging, etc. Nothing they do is resolving banging. Dropped pressure, lifted radiators, changed vents, etc. Posted pictures on this site- many feel piping was incorrect. Company has a talk-to-the-hand resolution department; they are no longer attentive. Suggestions for alternatives to press company with. Should I get another opinion, have repairs made, and go after company for such repairs? Where do you go when you are in need of heating expert, a specialist, West/South of Boston? Is installation of heating systems part one, and problems with hammering soley the customers problem? Never had such issues with old, 60 year Am Standard boiler. The noises are brief, but so loud, heating the house at night - with kids- is unacceptable.
Skimming
Is the water in the sight glass bouncing around a lot when making steam?
Did they do anything else besides installing the boiler?
Did they change the main vents?
Did the skim the boiler after installing it and if so how long did it take?
If you know what distributor they used you could try getting them involved.
Did you post pictures before, if so where are they.
3PSI gauge0 -
photos
of boiler and associated piping?0 -
Who to talk to
in your area -- south and west of Boston, is Charles Garrity. Top notch. You can find him on find a contractor for Massachusetts. 413.821.6726
There are any number of installation problems which can cause banging and gurgling and all that sort of thing -- unfortunately. And almost all of them are the result of the installer having a problem...Br. Jamie, osb
Try
Try calling J A Phinney in Milton, he's listed under the find a contractor banner. he's a knowledgable steam guy.
3PSI gauge0 -
Thanks for the recommendation Jamie
My Number is 413- 841- 6726 though.Cost is what you spend , value is what you get.
cell # 413-841-6726
Talk to the hand
Don't forget to post some pictures of your boiler piping.
If you get a real steam expert in, your problems will be solved, but in the meantime there may be some things you can do yourself to lessen the problems, based on advice here, once we see your pipes.--NBC0
- 120 Geothermal
