Uonor Hepex with Rehau Probalance Maniford
NT3041
Member Posts: 11
Is Hepex connected to a Rehau Pro Balance Manifold acceptable?
Thanks
Thanks
Sure
As long as you use the right size connectors.Bob Boan
R20 Fittings
Do you mean that I use Uponor R20 adapters on the Rehau Probalance Manifold?
Thanks0 -
RS20 Adaptors
The adapters come separately. If Uponor's are RS20, then they should fit. But Rehau sells them separately for the particular pipe size the you're using.They call them "connectors" and they come in pairs.Bob Boan
Rehau R20 on Hepex
If Rehau adapters would fit Uponor Hepex I would be all set. I have Hepex and a Rehau Probalance Manifold
Thanks Again For Your Help..0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
