Uonor Hepex with Rehau Probalance Maniford
NT3041
NT3041 Member Posts: 11
Is Hepex  connected to a Rehau Pro Balance Manifold acceptable?
Thanks
  • Ironman
    Ironman Member Posts: 7,840
    Sure
    As long as you use the right size connectors.
    Bob Boan
  • NT3041
    R20 Fittings
    Do you mean that I use Uponor R20 adapters on the Rehau Probalance Manifold?
    Thanks
  • Ironman
    RS20 Adaptors
    The adapters come separately. If Uponor's are RS20, then they should fit. But Rehau sells them separately for the particular pipe size the you're using.They call them "connectors" and they come in pairs.
    Bob Boan
  • NT3041
    Rehau R20 on Hepex
    If Rehau adapters would fit Uponor Hepex I would be all set. I have Hepex and a Rehau Probalance Manifold
    Thanks Again For Your Help..
