Beckett Auqasmart and OVD
crazy907ak
Member Posts: 34
I recently purchased a beckett aquasmart and a field controls oil vent damper and i noticed in the aquasmarts directions they say remove jumper wire on six pin connector if using vent damper. The ovd didnt come with six pin connector but does have optional wire harness that i could purchase prob not locally though. In the beckett aquasmarts directions it also mentions that if i remove jumper the device will only work with vent damper and can never work again without one even if jumper is replaced.
Is there a way of wiring it without six pin connector?
Am i understanding this correctly or are the referring to a burners auto vent like in a riello
burner ?
burner ?
Gas
That is for the 24V Aquasmart,gas only0 -
Thanks you
Didnt pay enough attention to 7600 AorB0 -
Circ off delay
Aquasmart has circ off delay. Much better to purge the residual heat at end of cycle to the house than using a vent damper0 -
System 2000
If you read their literature, you'll see that purging residual heat to the home increases efficiency.0
- 50 Industry Classes
