Peerless ect 06 2.75
Steve_210
Member Posts: 646
Just Done some work at this building
Gorton number 2 Main Vents, change radiator valves, Hoffman 40 radiator vents.
Question boiler has a 2 inch header installation manual calls for a 3 inch
When I suggested changing homeowner wants to know what benefits could Be seen from doing this
Looking for some suggestions thanks in advance guys
More space
I'd say there are at least two reasons for an oversized header. One, it slows down the steam so that any water carried along from the riser can drop out in the header and two, it provides more room for the water on the bottom of the pipe to keep separated from the steam at the top of the pipe.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Thank you Alan
Problem is it does not seem to be causing any problems right now
I guess my real question is will it improve efficiency anything
Quite a bit of work involved and I don't want to put him to Any unnecessary expense
The Larger Header would definitely purchase dryer steam0 -
Benefits from following instructions
Maybe this is not the time to cut out the old shrunken header.
You could ask them to listen for wet-stem rattles in the radiators this winter, and then perhaps they will agree to have it changed in the spring.
My guess is only a 5% difference in efficiency of fuel use, but maybe 10% in comfort.--NBC0 -
Thanks Nicholas
Since posting one of 6 Tenants have complained of a radiator Spitting
Makes you wonder how many are not Complaining
Once they have Heat, What do they care.
We are repiping the boiler within the next week thanks again0 -
Be sure
to take plenty of before and after pictures and post them!All Steamed Up, Inc.
Consulting0 -
Will do
Thanks again0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
