Radiant Heated Slab
Stewart Terrien
Member Posts: 11
in Gas Heating
I have a 28' x 40' garage with five 200' loops of 1/2"pex tubing in the slab. What is your recomendation for a wall mounted direct vent condensing propane boiler? Thanks.
without knowing more
(like a proper heat loss calculation) I'd probably be looking at a Triangle Tube PTS60 or a Lochinvar WHN-055.0 -
the Triangle tube...
unit is nice. Another option I would consider is the Bosch Greenstar 57.0
- 87.2K THE MAIN WALL
- 118 Chimneys & Flues
- 112 Geothermal
- 164 Indoor-Air Quality
- 73 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
