Radiant Heated Slab
I have a 28' x 40' garage with five 200' loops of  1/2"pex tubing in the slab. What is your recomendation for a wall mounted direct vent condensing propane boiler?  Thanks.
  • SWEI
    SWEI Member Posts: 7,348
    without knowing more
    (like a proper heat loss calculation) I'd probably be looking at a Triangle Tube PTS60 or a Lochinvar WHN-055.
  • kcopp
    kcopp Member Posts: 4,663
    the Triangle tube...
    unit is nice. Another option I would consider is the Bosch Greenstar 57.
