Check out this set up...
kcopp
Member Posts: 4,628
saw this on Cragslist.... <a href="http://crosslinkconversions.com/">http://crosslinkconversions.com/</a>
Bombs Away:
I was really impressed with the 6 gallon electric water heater rigged up as a bomb tank with the outlet going through the relief valve tapping on the top of the boiler.
I wonder if there is any nationally recognized testing group that has approved that?
Doesn't matter though, someone will buy one, install it themselves, and be sleeping over a bomb.
Lovely.0 -
It's magic
Are they condensing flue gases, or is this just hand-waving?
Most people have cooked a hot dog on a campfire. When you place the hot
dog above the flame you take advantage of the heat that is present. The
amount of heat that is produced by the campfire is barely affected.
Using the same concept, the system’s hot water heat exchanger is
directly in the flame taking advantage of the heat that is present.
There is minimal to no change in temperature of the hot air that is
dispersed into the room where the stove is present. The hot water is
then circulated through a loop system delivering heat to the attached
appliance.0 -
How to get your sphincter to do the momba...
1. Have boiler running at full output capacity.
2. Get hit by a power outtage...
3. Grab new roll of TP, and begin cleaning yourself up.
GREAT idea, but obviously not yet worse case scenario tested. The power of steam is simply amazing, especially when its not being controlled.
Ben there, done that, have the stains to prove it ;-)
I "accidentally" melted one down once. Not something you'd want to repeat in your lifetime...
ME0 -
Fine Print Options:
I can see you just don't understand and didn't read the fine print.
You buy the "optional" UPS like you use on your computer, only much bigger. You wire the circulator and controls through the UPS. That way, if the power goes out, the circulator pump will continue to operate. There there is "cool down" linkage that shuts the thing down. It has a safety device that stops the flow of fresh air to the stove and it has been computed that if the circulator runs for at least i hour, it shouldn't overheat.
That's an option that is part of their UL application but results are pending. When they sell enough prototypes, they will hopefully have the money to pay UL for their listing. CSA has already rejected it (I heard).
It's my experience that most cheapskates won't go with the optional safety device because some may be Off Grid and have no way to keep the battery in the UPS charged.
With the Temp. Pressure relief valve removed on the buffer tank, it will not open on high temperature, and as long as the pressure doesn't rise enough to to blow any fitting apart, you only need to worry about the temperature getting high enough to melt the 50/50 solder (which melts at 360' F) which is highly unlikely. Those things only used to happen in the old days. Like old Brown Bros. copper storage tanks connected to sidearm heaters with no safety shut off and the relief valve 30' away so if it opened, it wouldn'tt drain on the floor but into the sink below it. Just before the solder melted on the band holding the two halves of the tank and it became a steam powered missile and blew up the house.
That was in the old days. That doesn't happen any more. Things have changed now.0
