Vacuum Vapor - oil or gas?
Steve_55
Member Posts: 30
I have a large house on Long Island NY with a two pipe vacuum vapor system, currently running rather efficiently I think with oil. In 2008 I got a new peerless Boiler (EC ECT 06 W/S) with a Riello Series 40 (Model F10) burner and with a White Rodgers mechanical thermostat. The house has 4,700 sq feet to heat, and being mindful of the thermostats we use +/- 1,300 gallons a hear, so at today's $4+ oil prices, that is over $5k a year.
The system works fine, so I never considered a conversion to Gas, but at these prices, I want to ask if I should??
Any suggestions much appreciated
Merry Christmas Happy New Year to all
Steve
Steve
do the numbers
http://www.eia.gov/neic/experts/heatcalc.xls will help with your decision. Looking at http://www.bls.gov/ro2/avgengny.htm, assuming the same efficiency for both fuels, and comparing $3.93 oil with September NG prices shows a 60% reduction in cost.0 -
Thank you SWEI ....
...The numbers make it look like an easy save; guess I was wondering if a large/older/unique system running on Oil for almost 90 years can successfully be converted, or might I be asking for trouble.0 -
Steam
The system doesn't care what fuel is used...but your wallet does!0 -
Costs
Gas was/is always for over 20 years, less. Anybody that tries to compare BTU per unit, is full of DOO DOO!. A modulating burner will reduce energy consumption! A Tekmar indoor / outdoor control will help in reducing costs!0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
