gypcrete vs levelfloor
cobra
Member Posts: 1
I just had "Levelfloor" poured over radiant tubing. I understand it is a better product than Gypcrete.
The day after it was poured, we had 0 deg temps and I believe the product froze.
Does anyone know what I can expect? I hear about Gypcrete crumbling if frozen. Can I expect the same from Levelfloor? If so, what can I do??
I'm thinking...
if it has water in it, it is going to crumble. There are only so many ways to make a "crete", regardless of wether it is Gyp, Con or other, and they all require the use of water, which if allowed to freeze, will expand by 20% of its original volume, which is where the problem comes from.
I know my Gypcrete dealer REQUIRES that heat be available during a winter pour and its only function is one of keeping the gyp from freezing during the first 72 hours of life.
Check with the Level floor suppliers and see what their response is.
ME0 -
You can expect
That it froze. Was winter protection used? concrete blankets anything? It will crumble as been stated. now, and for ever. Needs to be ripped out, and redone. Your installer should have known way better then that.
Are you sure of the name of the product use. Not that it matters not any mortar, or concrete products that take 0 degrees well after being poured with out proper protection.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
