rpm
Paul S_3
Paul S_3 Member Posts: 1,295
can anyone tell me if the newer 90% plus warm air furnaces blower motor run at a higher rpm than the standard 1075 rpm....and if they do why??
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • will smith_4
    will smith_4 Member Posts: 259
    hmmm
    higher than 1075? Unlikely. Higher efficiency units will typically have lower speeds based on demand; at "low fire", you'll have lower rpm-less demand-less required airflow, but that will vary as demand changes.
    Why do you ask?
