rpm
Paul S_3
Member Posts: 1,292
in Gas Heating
can anyone tell me if the newer 90% plus warm air furnaces blower motor run at a higher rpm than the standard 1075 rpm....and if they do why??
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
347-692-4777
ASMHVACNYC.COM
hmmm
higher than 1075? Unlikely. Higher efficiency units will typically have lower speeds based on demand; at "low fire", you'll have lower rpm-less demand-less required airflow, but that will vary as demand changes.
Why do you ask?0
- 87.4K THE MAIN WALL
- 122 Chimneys & Flues
- 116 Geothermal
- 15.8K Strictly Steam
