Recording thermometer
pmck
Member Posts: 3
I'm looking for a thermometer to record room temp over the course of a week. Any suggestions?
Tracker
I use a Dickson tracker for air and liquid tracking. It is easy to use and plugs into your USB port. The software is simple to use. www.dicksondata.com0 -
Data Loggers
We have used Dickson and HOBO Ware, both are easy to use0 -
Thanks
Thanks for the help0 -
Supco
SUPCO also has a full line of inexpensive data loggers.
I've used both the dual temp probe type and the temp/humidity recorder.
Both have sold many jobs once I prove problem0 -
HOBO
I have used HOBO series temp loggers from Onset Comp extensively both in the lab at work and monitoring stuff at home (temps in my heating system, and once a shipment of wine across the country). Their stuff is fairly inexpensive, rugged, and easy to use.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 947 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
