Recording thermometer
pmck
Member Posts: 3
I'm looking for a thermometer to record room temp over the course of a week. Any suggestions?
Tracker
I use a Dickson tracker for air and liquid tracking. It is easy to use and plugs into your USB port. The software is simple to use. www.dicksondata.com0 -
Data Loggers
We have used Dickson and HOBO Ware, both are easy to use0 -
Thanks for the help0 -
Supco
SUPCO also has a full line of inexpensive data loggers.
I've used both the dual temp probe type and the temp/humidity recorder.
Both have sold many jobs once I prove problem0 -
HOBO
I have used HOBO series temp loggers from Onset Comp extensively both in the lab at work and monitoring stuff at home (temps in my heating system, and once a shipment of wine across the country). Their stuff is fairly inexpensive, rugged, and easy to use.0
