Copper Fin steam rad help
kmh5147
Member Posts: 20
Can someone please help me figure out the edr of some copper fin steam radiators I have on the first floor in my home? I am finding it very difficult getting information on calculating these for steam.....
They are 2 inch steel pipe with 4x6 inch copper fins spaced a 1/16 apart:
One is 35" and the other is 47"
Thanks!
Thanks!
photos would help
if you post a photo we can probably figure the manufacturer and go from there.Cost is what you spend , value is what you get.
cell # 413-841-6726
That is slightly difficult
they are barried into the wall with an opening of about 3 inchs and then the fin rad then about 5 inches up is the wall grill. I have these on the first floor, only in the dinning room and living room. I dont believe that these were a retrofit after the system, also the system is a trane vapor vac.0
