Copper Fin steam rad help
kmh5147
Member Posts: 20
Can someone please help me figure out the edr of some copper fin steam radiators I have on the first floor in my home? I am finding it very difficult getting information on calculating these for steam.....
They are 2 inch steel pipe with 4x6 inch copper fins spaced a 1/16 apart:
One is 35" and the other is 47"
Thanks!
Thanks!
photos would help
if you post a photo we can probably figure the manufacturer and go from there.Cost is what you spend , value is what you get.
cell # 413-841-6726
That is slightly difficult
they are barried into the wall with an opening of about 3 inchs and then the fin rad then about 5 inches up is the wall grill. I have these on the first floor, only in the dinning room and living room. I dont believe that these were a retrofit after the system, also the system is a trane vapor vac.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 158 Indoor-Air Quality
- 3.5K Oil Heating
- 68 Pipe Deterioration
- 938 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
