Copper Fin steam rad help
Can someone please help me figure out the edr of some copper fin steam radiators I have on the first floor in my home?  I am finding it very difficult getting information on calculating these for steam.....
They are 2 inch steel pipe with 4x6 inch copper fins spaced a 1/16 apart:
One is 35" and the other is 47"
Thanks!
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    photos would help
    if you post a photo we can probably figure the manufacturer and go from there.
    cell # 413-841-6726
  • kmh5147
    kmh5147 Member Posts: 20
    edited December 2012
    That is slightly difficult
    they are barried into the wall with an opening of about 3 inchs and then the fin rad then about 5 inches up is the wall grill.  I have these on the first floor, only in the dinning room and living room.  I dont believe that these were a retrofit after the system, also the system is a trane vapor vac.
