Installed my new low pressure gauge
pcloadletter
Member Posts: 38
Ordered a Wika 0-3 psi gauge from gaugestore.com and installed it tonight. Reworked some of the pigtail piping to incorporate a union where the assembly meets the boiler so I can remove the whole thing if I want to work on it. Added a tee and a nipple for the new gauge. It works pretty well - my system barely broke 0.2 psi until it hit 0.5 psi right before the thermostat shut off. I think that's pretty good. Thoughts?
Looks good
That will work very well for you. It sounds like your boiler is well matched to your EDR.
3PSI gauge0 -
Looks good.
Looks good except for one thing.
When I originally installed my gauge it kept getting water in it over time. I assume small amounts of steam somehow end up there and condense in it.
Later I moved it up higher and this problem seems to have gone away. Hopefully these picture links will work.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0 -
Should I fill the pigtail?
Okay so when I was putting everything together I thought, "should I add some water down the pigtail?" and I decided to pour some water down where the low pressure gauge would be. I thought maybe the steam would condense and fill up the trap but I wasn't sure. Comments?0 -
pigtail
I filled mine but I think even if you don't steam will condense and fill it as well.Single pipe quasi-vapor system. Typical operating pressure 0.14 - 0.43 oz. EcoSteam ES-20 Advanced Control for Residential Steam boilers. Rectorseal Steamaster water treatment0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
