zone issue
coldnorth
Member Posts: 3
i need to replace a zone valve with a circulation pump. Does anyone know how I would go about wiring the pump to the t/stat?
thanks
thanks
Yes
Via a switching relay.0 -
Why?
You need a separate relay, flow check, and knowledge of piping. Why do you need to replace a zone valve with a circ?0 -
Why:
Ditto (To the question of Billtwocase).0 -
Yes
Get a RIB [relay in a box] break the 110v to the circ. through the normaly open contacts and wire the t'stat the 24v coil. Done0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
