8184 to 7184
needinghelp
Member Posts: 1
I am replacing the entire burner unit in a Lennox O23Q2-70-1A oil furnace. The old unit used a R8184 M 1002 primary controller and the new one has a R7184B 1032. The old unit ran three wires to primary (24 volt power, WI, and Common) and the new unit only has two terminals( T and T). I have tried several combinations like 24 volt and WI to T and T and the burner would run but no blower until burner shut down. Also common and WI to T and T and that worked but no tstat control(stayed running). Tstat to primary and I don't get 24 volts to blower control. Is there a way to wire this and still have all safeties in place?
Trying
Maybe being able to see what you had will make it easier? https://customer.honeywell.com/resources/Techlit/TechLitDocuments/70-0000s/70-3709.pdf0 -
24v
24v power which is ''r'' & ''w1'' go too ''t''&''t''....do away with the common....does your furnace have a/cASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0
- 50 Industry Classes
