reset ratio?
keh
Member Posts: 1
Can anyone explain to me what a reset ratio setting is? Or direct me to a
good article explaining it? I get that it has to do with the outside
temp dictating how much the boilers have to heat the water to compensate
for increased heat loss at colder temps. What I don't understand is how
this is generally figured.
What got me wondering is I am on my
second winter as the licensed overseer of the boilers at the apartment
complex I work at. I think I have a pretty good handle on everything
except the settings of the microprocessor controller.
There are
three setting knobs. One for temperature set point (in degrees F), One
for reset ratio (in ratios ex: 1:1 etc..) and one for control band.
I should also mention that the system consists of 6 Slant/Fin Caravan gas fired boilers.
My
predecessor was also somewhat bewildered by the system and treated it
like a simple aquastat, as he told me to turn up the temp set point knob
as it got colder outside. This, however, makes no sense to me since the
system is supposed to automatically compensate for this, which, for the
most part, it does. I should be able to set if and forget it, no?
So
in a nut shell, I think the settings must all be screwed up by this
point, and I want to figure out where I should set them back to. So.... Is this something I can figure out with a little more research and the control module's manual? Or will I
need to call in a professional?
There are
My
So
Here is a link.
http://www.slantfin.com/images/stories/Technical-Literature/caravan_sc9_control_sc3_40.pdf
Those boilers are staged. You may need to call in a pro to dial in that control.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
