steam systems
my Hvac teacher wants us to find the difference between 1 pipe and 2 pipe systems in steam boilers.  Can anyone help?
  • Dave in QCA
    Dave in QCA Member Posts: 1,806
    Well, The simple answer is
    A one pipe system has one pipe and a two pipe system has two pipes.  In a one pipe system both the steam and the condensate travel in the same pipe.  in a two pipe system, the steam travels in one pipe and the condensate and venting occurs through the other pipe.
    But, that is far too simple and I suspect that your teacher expects you to learn a little more than that, perhaps even understand the systems.   Here is a link to a good publication that shows many basic types of steam systems.  Spend a half hour and read, read, read.  After a while it begins to get interesting!   http://documentlibrary.xylemappliedwater.com/files/2012/07/HS-901A.pdf
    Hope you get an A in the class!
    Dave in Quad Cities, America
    http://grandviewdavenport.com
