steam systems
ValS2012
Member Posts: 1
my Hvac teacher wants us to find the difference between 1 pipe and 2 pipe systems in steam boilers. Can anyone help?
Well, The simple answer is
A one pipe system has one pipe and a two pipe system has two pipes. In a one pipe system both the steam and the condensate travel in the same pipe. in a two pipe system, the steam travels in one pipe and the condensate and venting occurs through the other pipe.
But, that is far too simple and I suspect that your teacher expects you to learn a little more than that, perhaps even understand the systems. Here is a link to a good publication that shows many basic types of steam systems. Spend a half hour and read, read, read. After a while it begins to get interesting! http://documentlibrary.xylemappliedwater.com/files/2012/07/HS-901A.pdf
Hope you get an A in the class!Dave in Quad Cities, America
http://grandviewdavenport.com0
- 120.1K All Categories
- 83.6K THE MAIN WALL
- 2.8K A-C, Heat Pumps & Refrigeration
- 52 Biomass
- 414 Carbon Monoxide Awareness
- 29 Chimneys & Flues
- 1.7K Domestic Hot Water
- 4.6K Gas Heating
- 114 Geothermal
- 151 Indoor-Air Quality
- 2.9K Oil Heating
- 49 Pipe Deterioration
- 734 Plumbing
- 5.2K Radiant Heating
- 355 Solar
- 13.8K Strictly Steam
- 3K Thermostats and Controls
- 50 Water Quality
- 36 Industry Classes
- 69 Job Opportunities
- 14 Recall Announcements
