Cooling Tower Specifications
Potterish
Member Posts: 13
Hello Everyone,
Many types of machines and equipment generate a great deal of heat. To get rid of much of this heat, engineers often rely on cooling towers, which take cool water and air and remove heat from various sources. These towers are enormous and have various unique specifications depending on the environment that they will operate under and the extent to which the owners want to remain efficient and environmentally friendly.
Thanks and Regards,
Harry Potterish
<a href="http://www.merusonline.com/in-industry/cooling-towers">Evaporative Cooling Tower</a>
Thanks and Regards,
Harry Potterish
DHW?
How do cooling towers relate to DHW?"If you can't explain it simply, you don't understand it well enough"
Albert Einstein0 -
I think he's casting spells at us
Extremispamus, to be specific.0
