24v vxt 24v safgard 400 110v burner
USA498
USA498 Member Posts: 45
Attempting to upgrade burner controls with a VXT 24 and safgard 400 24v. I have set up the power for both and the cutoff for the burner but I am having trouble figuring out how to hook up the VXT to the safgard for the autofeed to work. The schematic is saying I need to hook up the feed on the vxt to the A on the safgard which I have done but thne it says I need to connect the line load to to H on the VXT and connect the common to N on the vxt. This does not make much sense to bring 110v into the VXT to me. Am I reading this right ?
Thanks for your help !
    Steamhead Member Posts: 17,892
    What boiler
    are you using these controls on?
    Consulting
  • USA498
    boiler
    an old peerless steamer jottw-175-s
  • Hap_Hazzard
    Hap_Hazzard Member Posts: 2,917
    Why?
    Both those controls are available in 120v. Why would you try to install 24v controls on a 120v gas valve?
    The main difference between the VXT 24 and 120 is that the 120 has a transformer on the circuit board where the 24 has a dropping resistor, and a 120v coil on the DEMA valve.
  • USA498
    will it work ?
    I guess i'm asking if these two devices will work with a 110v burner. If they can how would they get wired up. I got them off ebay at a good price so i am somewhat stuck with them. Maybe i should put them back on ebay and get the vxt 120 and the safguard 450.
  • Hap_Hazzard
    Wait a sec
    Isn't the JOT-TW175 an oil burner?
    edited November 2012
    Unless someone has put a gas burner on it
    but even so, it would still use line-voltage controls.
    USA498, you might want to post the 24V units on the Buy, Sell, Barter page here. I'm assuming they are new, rather than used?
    Consulting
