24v vxt 24v safgard 400 110v burner
USA498
Member Posts: 45
Attempting to upgrade burner controls with a VXT 24 and safgard 400 24v. I have set up the power for both and the cutoff for the burner but I am having trouble figuring out how to hook up the VXT to the safgard for the autofeed to work. The schematic is saying I need to hook up the feed on the vxt to the A on the safgard which I have done but thne it says I need to connect the line load to to H on the VXT and connect the common to N on the vxt. This does not make much sense to bring 110v into the VXT to me. Am I reading this right ?
Thanks for your help !
What boiler
are you using these controls on?All Steamed Up, Inc.
Consulting0 -
boiler
an old peerless steamer jottw-175-s0 -
Why?
Both those controls are available in 120v. Why would you try to install 24v controls on a 120v gas valve?
The main difference between the VXT 24 and 120 is that the 120 has a transformer on the circuit board where the 24 has a dropping resistor, and a 120v coil on the DEMA valve.Just another DIYer | King of Prussia, PA
will it work ?
I guess i'm asking if these two devices will work with a 110v burner. If they can how would they get wired up. I got them off ebay at a good price so i am somewhat stuck with them. Maybe i should put them back on ebay and get the vxt 120 and the safguard 450.0 -
Wait a sec
Isn't the JOT-TW175 an oil burner?Just another DIYer | King of Prussia, PA
Unless someone has put a gas burner on it
but even so, it would still use line-voltage controls.
USA498, you might want to post the 24V units on the Buy, Sell, Barter page here. I'm assuming they are new, rather than used?All Steamed Up, Inc.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
