steam boiler reservoir tank
gerry gill
gerry gill Member Posts: 3,083
for sizing the reservoir tank to be added to an undersized steam boiler..we have a job where the replacement steamer is 800 sq.ft. but the house is 1080 sq.ft. and the near boiler piping is not right, so between the two the boiler ends up at low water..the owner is way overbudget on his rehab so we wanted to add a reservoir tank to help with the water..his original coal boiler was acting as one but is being removed as part of the rehab..weil-mclains instruction sheet shows how to install it but offers no sizing criteria...any help would be appreciated.
gwgillplumbingandheating.com
    Steamhead Member Posts: 18,211
    Are you talking about
    just a tank, or a "boiler-feed pump" which includes a tank?
    Consulting
  • gerry gill
    just a reservoir tank.
    it would sit next to the boiler, have an equalizer and the bottom would be piped into the wet return..basically a big fat A dimension.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,686
    Those things
    have never made any sense to me, Gerry.
    Retired and loving it.
  • gerry gill
    well, it should replace water
    to an undersized boiler, its on page 17 of the attached file from weil-mclain..the old timers here in clevelands master plumbers league swear they work to solve a problem of a boiler going off on low water due to being to small..my first time running into this situation..guess i'll find out..i understand the theroy is if the boiler drops one inch in water, than one vertical inch will push back into the boiler from the tank, but that one vertical inch may be composed of hundreds of horizontal inches..i'll let you know if it works..actually i already know it works cause the undersized gas boiler maintained a mid-glass level, till we disconnected the old coal boilers return, it has been acting as a reservoir tank all these years.
  • DanHolohan
    The challenge
    is you have to get all the water physically located within the boiler's operating range. This means you have a pretty long tank. I've always wondered if that tank should be ASME rated. I've also wondered what it does to the boiler's efficiency.
    These things first appeared in the 80s when manufacturers were offering steam boilers that had very narrow sections. These would often go off on low-water when the boiler reached high pressure limit. When you consider that one cup of water becomes 1,700 cups of steam, you start to wonder what use these tanks are. Assuming, of course, that it's a well-piped and well-cleaned boiler.
    Just my two cents, Gerry.
  • Earthfire
    Earthfire Member Posts: 543
    Is the sg ft. necessary due to load , might not it be better to downsize some of the existing radiation if it is oversized for load. Is this an existing boiler or a new replacement?
  • gerry gill
    yup, thats one of this boilers
    problems..its not piped well, and is to small..the boilers installer got away with it only cause the coal boiler was holding water to assist it..big coal boiler..lots of water..the owners so overbudget on his rehab, that he can't afford a new boiler, which of course was our first pitch..i'm sure a new boiler would be much,much more efficient in the long run..but he won't have it..right now the system has to run long enough for the pipes to heat up, then when the piping pickup factor drops out of the equation, the boiler can then heat the building..not efficient by any means..how we got involved was it was our job to separate the old boiler from the system so he could get rid of it..thats when we found out the hard way the old boiler was still actually doing something..opps,,don't ya just hate when that happens ;)
  • gerry gill
    everythings existing
    except of course now the old coal boiler...
  • Mad Dog
    Mad Dog Member Posts: 2,595
    Me thinks the $$$ would be better spent on
    a header and near boiler repipe, and then, a very thorough cleaning. Keep that water IN the boiler by keeping it dry and under control. Thanks fot the book Gerry - loved it. Mad Dog
  • OD
    OD Member Posts: 1
    Reservoir
    Best suggestion is to cycle the system through two or more cycles. Drain system into a container until it reaches correct level in sight tube. What you have drained out will give you a good idea on what minimum size reservoir you will need.
  • Jason_13
    Jason_13 Member Posts: 305
    . Sizing
    I assume you rechecked the load without pick-up and verified all the mains, near boiler piping and vertical runs in the basement are all insulated. This reduces the pick-up factor and adds to usable steam. If you don't need 33% pick-up it runs over to usable steam.
    Slow down all vents to reduce radiator size if possible. The only time you need 1080 sq ft is if all rads heat all the way across. Most steam systems today need to only heat 3/4 of the way across or less residentially due to building updates.
  • jumper
    jumper Member Posts: 2,501
    enough headroom ?
    If there's enough room a condensate receiver sounds excellent to me. Supply to boiler with a float valve. I don't see why an ASME stamp is called for. Pumps for steam heating are oversold. As a guess I'd make the tank capacity twice that of the boiler and begin with the tank half full. Frankly the bigger the tank the better. Weren't there multi story buildings with two tanks in series , the higher one being a flash tank?
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    I would start with checking
    the return piping. I find those tanks on systems with clogged or undersized returns. Weil Has charts on their web site that list the size of 8" pipe or gallons for a given boiler in the installation manuals based on the run time for a cycle. I will look for a link.
    cell # 413-841-6726
  • jumper
    if it is big enough
    If a simple receiver is big enough it will minimize level fluctuation. That's the simplest. But it is not that complicated to make a controlled level system. Like an automatic feeder. Except that the supply is condensate instead of an infinite supply of raw water.
