Corroded Buried Steam Line
Charlie4255
Member Posts: 2
Our church has a buried steam line that serves two buildings. Dec '08 the line failed and was replaced with a fusion bond carbon steel pipe. It has corroded through and must be replaced again. The corrosiion is from the outside. The backfill is sand and pea gravel.
The contractor is proposing to use a DuraBond X-TecTruCoat Schedule 40 pipe with cathode protection via a sacrificial anode.
I suspect the premature failure is either from the wrong type pipe, the wrong type backfill or a combination of the two.
Any suggestions?
Any suggestions?
What size pipe
and how long?All Steamed Up, Inc.
Consulting0 -
where is the corrosion ?
One spot or the whole thing has rotted ? Air plus hot water on steel is bad. If a coating works it would be very good. A drained conduit is a good long term investment.0
- 109 Chimneys & Flues
- 975 Plumbing
- 386 Solar
- 17 Recall Announcements
