Dresser Compression coupling vs threading a steel pipe
elfie
elfie Member Posts: 266
have a 1 1/4" steel pipe being used on a hot water heating system
I am planning to install a check vallve along the pipe (unable to remove pipe from above some ceiling tiles so would need to cut out about 6-9 inche of pipe length)
would it be better to use a dresser compression coupling vs. threading two steep pipe ends to facilitate installation of a check valve?
heard dresser couplings are very reliable
thanks
  • Jim Godbout
    Jim Godbout Member Posts: 49
    Repair
    Try progress for steel
    It works great for this type of repair
  • Tim McElwain
    Tim McElwain Member Posts: 4,660
    I think Jim meant
    Propress not progress, sorry Jim if I ma wrong!
  • Jim Godbout
    You are right
    Computer always correcting my spelling
    Thanks
    Jim
  • elfie
    black pipe
    does it work on black pipe, and is it better than threading?
    why would anyone ever thread a steel pipe with these types of couplings? especially when you can't remove a pipe and bring it into a workshop to get help from a vice
  • Jim Godbout
    propress makes repair very easy
    here is link to Propress with iron pipe
    we use it on oil-gas, hot water, solar, low pressure steam and compressed air
    http://www.viega.net/cps/rde/xbcr/en-us/Viega_MegaPress_Systems.pdf
    http://www.viega.net/cps/rde/xbcr/en-us/Viega_ProPress_Systems.pdf
    take care
    jim
  • SWEI
    SWEI Member Posts: 7,342
    ProPress questions
    I noticed that the ProPress catalog lists low pressure steam (with the FKM gaskets) but the MegaPress only shows EPDM and HNBR gasket options. I've been eying their stainless stuff for awhile now (rep tells me that thinwall 304 now costs less than copper.)
  • elfie
    steel pipe threading
    so does all this mean that steel pipe threading is unnecessary?
    why would anyone thread a steel pipe in light of compression couplings?
    we hired a plumber that was planning to thread steel pipe and never advised on this alternative.
    thanks
  • Gordo
    Gordo Member Posts: 857
    edited November 2012
    Threaded Steel Pipe
    Threaded steel pipe has been around a LONG time.  A Dresser couping I would regard at best as a temporary repair, esp. on anything that undergoes wide temperature swings.  On hot water systems, I've seen them last awhile.  I've seen 'em leak, too.
    I'd never use them on steam.  They always leak then.
    In regards to Propress, I've used it.  So far, it's worked out...on hot water.  The copper stuff only, not the steel.  Time will tell.
    On steam, I would never use it.  I'll let someone else be the Beta Tester on that one.  I've been burned way too many times on installing the latest gizmo and gotten no backup.
    In short, threaded steel works and has at least a century of success behind it.
  • Jim Godbout
    Many choices
    We all have options for piping some new some old
    We choose to stay on cutting edge following many techniques from European market which tends to explore mechanical engineering well before us in North America and it has worked out very well for us
    God luck in your decisions
  • RJ_4
    RJ_4 Member Posts: 484
    dressler
    I have used these couplings in different applic.  I used them alot to repair and replace steam condensate return lines. you need to check the gaskets that come with the coupling , for steam tou need the high temp gaskets (usually indicated by a green dot on the gasket.)  I would also coat both sides of gaskets with teflon pipe dope, never had any leaks
  • RJ_4
    dressler
